Hi I'm going to extend a ring around a conservatory it will be comming through from the upper floor into the peak of the conservatory roof above a door. It will then have to come down at an angle untill vertical above the sockets. I have steel conduit which i was intending to use. I've just thought it may not be nececery if i keep within 150mm of the roof.
I know that i can run cables within 150mm of celling and corners. But it never really crossed my mind that i can proberbly run it at an angle provided i keep it close to the roof.
What do you normally do in this situation steel conduit or just caping to protect from plastering keeping with in 150mm of roof
