Just purchased a Evergreen ST0311 multi fuel stove secondhand. Flue diameter on the stove is 127mm. I've fitted the stove to my exsisting fireplace which used to have a gas fire fitted sometime ago, the chimney is lined with a 7 inch flexible liner.
In the past the smoke test done by the gas man was fine for drawing the smoke up the chimney when the gas fire was on. I've simply stuck the enamelled solid steel stove pipe which is around 500mm long up in to the flexible steel liner. Unfortunately this does not seem to work as the fire does not burn very well even with the vents and flue damper fully open on the fire. The house is pretty old with no closed rooms.
Do i need to seal the gap between the stove pipe and flexible liner. If so please advise on the best method as I only have about 3.5" between the top of the stove and the liner closing plate. Thanks
