I recently moved to Devon, where I am living in a timber-framed chalet. There is a Morso Squirrel multi-fuel stove in the middle of the building. It has a boiler which is connected to the water tank. However I have not yet lit the stove because of 3 problems. 1. The top is cracked but I now have a new top and someone to fit it for me. 2. There is no hearth and the stove is on a laminate floor with wood underneath, but underneath that is concrete, so I am going to have the flooring cut away and a slab of slate fitted. 3. The stove is only 6cms from an internal stud wall. The surface of the plasterboard has already been damaged by heat. I don't want to move the stove because the flue goes straight up through the roof, because of the plumbing to the water heater, and because the space is small. I have read the regulations that there should be 75cm thick non-combustible material behind the stove, and also had varying advice - e.g. have a sheet of metal fixed on the wall with an air gap, or not to worry about it because the previous owner used it as it is. I am going round in circles thinking about this. Any ideas or advice?
I'm also concerned about the insurance situation.
