it sounds like the gurgling is at the top of the boiler when hot water running is it possible air trapped in the gas to water exchanger?you can have a shower or run a sink of hot water but when you turn off boiler goes off as the boiler gets really hot to touch so the over heat stat cuts it off which as just been changed as well as a new pump and also the dhw sensor. how do you get rid of air or descale? thanks
