Hi Guys
Long time reader, first time poster, here's hoping you can help me.
I've just moved house and found myself with a Worcester combi boiler, with all up-to-date tests and stickers. (think it was part of a British Gas service agreement until when I moved in)
Anyway, the first night we put the heating on for a "+1 hour" just to check it was OK. And it was, lovely jubbly, nice and warm. Only today when I come to it, when you switch it on, nothing happens. Upon checking the pressure gauge it's right down to zero. No problem I thought, I'll just top it up. Only, I can't find any way to do that? The last combi I had was a Vaillant and it had the mains cold water input with a valve that you just opened with a screwdriver.
Underneath this boiler are 4 pipes - the central heating flow and return pipes, mains cold water in (normally open, and when you turn this valve off the hot water stops working) domestic hot water out and the gas in.
There is a pipe that comes upwards from the top left (facing the boiler) and goes into the loft - that has a red valve like you see on some fire hose reels, and in the loft that goes into a small tank; although it's all covered up with bin bags and gaffer tape. The previous owner mentioned there's a small tank in the loft, but that it was disconnected from anything. (not sure if he knew what he meant?)
Reading the manual it mentions that you have to connect up a hosepipe to the central heating system to top it up, is that true? Or is there just some valve I'm missing to let water in? And could this tank be anything?
Any help appreciated, really would like to fix it myself rather than pay £££ on top of everything else moving house!
Thanks in advance,
Steve
Thanks in advance,
Steve
