IVE got a worcester 24cdi that was installed by british gas about six years ago it was placed in the origional cylinder cupboard and is on gravity feed from the header tank which is about 600mm above the boiler it has worked fine for the last few years but now it overheats and bangs and clatters when the hot water is run but the heating works fine. Ive checked the domestic hot water heat exchanger and that is not blocked also the diverter valve is functioning properly. Can anyone help as I have not come across this problem before
