Hi folks, just having a look around for advice and info regards a couple of faults with the above mentioned boiler.
The hot water runs hot(ish) and cold alternating. The hot water supply is slower and generally not as hot as it should be. It trips out occasionally (reset with a small button on top of the control panel) and now struggles to light up for hot water or central heating if its stands overnight. I'm thinking the heat exchanger is scaled up and the gas valve is u/s. I've had a local corgi man out and he says its probably the gas valve and will change it for £300, he also says the combi sounds scaled up and suggested full replacement at around £1500. I'm neither flush with money nor stupid so looking for some more opinions. I'm pretty mechanically minded and wondering if I could descale or replace the heat exchanger myself and also whether £300 for a gas valve replacement is excessive?
