I have a Worcester Bosch boiler, I think is about 10-15 years old, the type that heats water on demand there is no storage tank. I need to get a safety certificate, but want to get an ongoing problem fixed first and am keen to try to get as much information as possible before calling an engineer in the hope of saving money. If I definitely need a new part, I would say that the engineer could bring this and make one trip not two.
This is what happens.. There is an outside pipe located behind the boiler; it drips more or less constantly, at the same time pressure slowly falls. The pressure gauge has a marker for one bar, I tend to let enough water in so that it goes up to two bars and then about every 2-3 days I need to let more water in. I am not aware of any water leaks in the house and would say that if the issue was due a leak I would know, I am putting a lot of water in and on a regular basis
Clearly this can’t go on! It seems to me that it’s quite possible that whatever mechanism inside the boiler that is designed to release water due to too much pressure is faulty.
Any help much appreciated
