Worcester Gas Rating
14 Aug 2007
Hi all,
Anyone any idea if there is any tolereances with the gas rate on a Greenstar 37CDI?
M/I ask for 3.9,I've gas rated twice tonight so far and I'm getting 3.4
Why not ask W-B?
In my experience they tend to be a bit more rather than less if anything.
What is inlet pressure when going full blast?
Working pressure at the boiler is 20mb,All other readings with the FGA are as per M/I specs,I was just curious too see if there was a tolerance with the gas rating,I know Valliant have a minimum and maximum on the gas rating.
Cheers
thats on the input of the kw though. when gas rating are you doing it to work out the kw net. or m3/h.
id stick with the original gas rating formula if i were you.1st reading -2nd reading x30x38.79/3600=/1.11 thats acceptable to give you kw.then i think x 0.09 will give you m3/h
Easiest way
2nd reading - 1st reading = 0.081 m3 eg (over 2 mins)
x 30 to give m3/hr = 2.43 m3/hr eg
x 10.76 to give KW gross = 26.15 KW gross eg
/1.11 to give KW net
so 2nd - 1st x 30 x 10.76 /1.11 to give KW net
I usually use x 10.7 to give KW gross mj/m3 x 1000 / 3600
