Yes, you have the old 24i. I was thinking of the newer Junior 24i when I said that as we are getting a lot of them failing now.
Did you reset the o/h stat as advised?
The boiler lights the pilot just when heat is required. If it does not light itself then there is a fault. Its either not sparking or there is no gas at the pilot.
go to the top of the boiler,red button with a cross on press it down[/quote
thanks for your help I presed the reset buttom on top of the boiler that done the trick saved me shelling out £200 to worester for just the call out thanks great site keep up the good work
