Worester Bosch 280- hot water cuts out for a while mid showe
9 Jun 2009
Surrey
I have a worcester bosch 280 combi boiler. Its installed on the ground floor. It works fine throughout the house- en suite shower, all taps, rads etc apart from the shower in the loft (2nd floor). It always cuts out (i.e. water goes cold but no difference in pressure) for 30secs to 1 min halfway through a shower. I had the pressure at 1bar and increased to 2 bar just in case this made any difference which it doesn't. Any ideas??
How did you have the pressure increased to 2 Bar? Have you a shower pump by any chance? If so this must not be used with a combi.
The pressure is not too important, it is the flow rate that counts. If the flow is too low, the boiler will think the shower has gone off so shut down.
What shower is it? Have you any non-return valves on the shower feeds?
There's no pump and the shower is just a straight forward hose coming out of the wall. But I think I've solved it having thought about the 'flow rate' issue. I swapped over the shower heads as the loft shower head wasn't as free flowing as my en-suite one. I tried it this morning and it didn't cut out at all. Fingers crossed that'll be the problem. Thanks!
