can someone answer tell me this should i have open the following:
Central Heating Flow = Open
Central Heatinfg Return = Currenttly closed = should it be open as the plumber changed the diaphram and never come back???
Mains Cold Water In = Open
Domestic Hot water Out = NO SCREW(ADJUSTER)
Overflow goes outside - NO SCREW
GAS COCK + DO NOT TOUCH AS I KNOW IT WORKS AS WE HAVE HOT WATER.
I think the the return is closed as the pump goes, then trips the swith as the return is closed to return the water flow, should it be open?????
