Two minutes per joint does seem too long although I like the concept of it. I also like the idea of the baffle on the front although in practice it would be full of solder.
Would have preferred to see it being used one inch away from a skirting board rather than in a vice.
not sure why it needed a demonstration. Title was enough.
I guess its ok for diyers who dont wanna fork out for a blowtorch etc but no pro is gonna do that if they are any good. Like dan said you can avoid burning stuff by being careful and using a good fine tip on your blowtorch
Same here, they're pile of sh.te!! What's wrong with a few scorch marks anyway?? At least the home owner will know where you've been working & where to Hoover up after you, it gives these OAPs something to do - a bit of painting!
