Has any members used the above tool.So far have had reports of sudden kickbacks, from the saw.When cutting.As this Iis new on the market, I woul'nt know.
Thank you for the time to read.
have you got a link please
usually kickback is caused by expecting a tool[saw] to work well beyond sensible levels off performance or with material in far from ideal condition or indeed used in a way its not really designed for ---------
Worth bearing in mind that the saw in question has no riving knife, so if used free hand (i.e. not running against a guide batten or similar) you may well experience kickback if the direction of travel is changed mid cut
