Wt1 to cure damp floor
1 Jan 2017
Hi there I have a damp floor problem in a Victorian terrace,
I've levelled the floor using a floor screed, and plan to use WT1 to tank the floor, rolling up the walls a couple of inches
Can I then level again on top of WT1? Before laying wooden click floor,
I know this is a reality new product and unsure if anyone has used it it looks amazing stuff,
Or is there a better option?
Many thanks
Now I'm talking off the top of my head, but how well will the WT1 settle once you apply it. Do you need to bring the level of the floor up any further, or could you put fibreboard on top of the WT1, and then lay the flooring. But if you're going to do another screed, then the normal procedure would be to throw some dry sharp sand on top of the WT1 before it dries, and brush off the loose sand before laying the self levelling compound.
