Hello all, I am shortly having my CU replaced from HRC type to split load type. Question is - can these cheaper units be configured so that the 100amp incoming switch can be moved to the opposite end of the unit. Also I need a shower cable fitting for when we have new bathroom fitted in a few months. If the new 10mm cable is chased into plasterboard wall in corner (within 150mm ) up wall into loft - is it sufficient to have no conduit fitted. I am wary about a high load cable plastered into wall.
