XPS
21 May 2023
Georgia
I want to put XPS onto the outside of block exterior walls. Do I need to seal them first and, if so, what with. Also, how do I make sure that moisture doesn't get in at the top the bottom? Thanks!
Verge trim at the top, siliconed to the wall should stop water getting in from the top.
Stopping short of the ground above dpc should stop water from the bottom
Blocks shouldn't need sealing
