tell us the model number. The two most popular recent models are HSA6300 AND HSA6400
There are older models that are comparable but not identical, and newer models that are different.
Tell us how old it is and how long it worked for before this happened. Have you got the instruction book?
on the control panel, press the disarm key (green open padlock) then put in your code
You may have to do it several times.
The keyfob will not (depending on alarm model) stop an alarm caused by a Burglar sensor.
You did not say if the outdoor or indoor sirens are hooting.
Once you have cleared the "Alarm!" display you can look at the logs to see which sensor(s) triggered it, and if there is a fault log entry.
If you need to examine any sensors (e.g. to see if they were not tightly fitted and the tamper sensor went, or if the batteries need changing) set Tamper Off first.
