hi, have removed all obstructions and all pipeways clear, pump doesn't seem to work and makes funny noise. how easy is it to diy fit a new pump? thanks for any help
Either of these should fit your model. I think I would go for a pattern spare at a mighty £9. http://www.espares.co.uk/parts?k=1322082007 You ought to be able to change it easily enough by removing the rear cover. But if the machine doesn't have a baseplate you could lean it against a wall/stool etc & access it from underneath.
