There have been some heater relay issues on these models. Remove the pcb & check for popped/burned solder points on the underside of the relay. If you find none check the heater wiring for breaks/bad connections & check the thermostat on the sump. There are two different versions of this model; one has an electromechanical timer & the other is purely electronic control. Tell us which you have.
