My Zanussi essential washing machine will not turn the drum or allow water intake. Iv changed the motor brushes - but still the same. It will drain fine if you fill it manually with water but wont spin even if left for over 1 hour on the spin setting the drum will not kick in and turn. There are no blockages Iv checked every hose. Basically you turn it on select a setting it will start making the usual pump type noise but does nothing. Any ideas ?
