I have a Zanussi WJD1257W which suddenly did not want to spin. I went into diagnostics mode to try to check for any fault codes, and somehow managed to end up fixing the spin issue, but in the process also managed to turn the 'beeps' off, and had no heat on dry cycle.
Following some suggestions I found in a different forum, I managed to use the diagnostics mode to start the dryer and got heat.
The problem now is that in trying to get back out of diagnostics, I have somehow ended up with an E93 error, which I gather from google is a pcb configuration error.
Can anyone advidse me how to configure the pcb so I can try to get it working again? Product No is 914601406/00
Thanks in advance,
Thanks in advance,
