It's not decking mate. It's the foundation for the shed. Just the very end 20cm drops off. But I wanted the foundations in solid ground rather than the slabs.
I get that it is not decking.
My understanding is that you are trying to protect the OSB bit that will stick out from back of the shed (and sides?) from rain. My thought was to cover it with DPM, then a couple of decking boards to hold it all down and make it look tidy.
"A drain for sink and power". Building regulations will be required for drain connection and the electrics need competent design for safety, especially as you have a metal shed. (one of the sparks on this site may comment further on this)
Cut back all the OSB that will be uncovered, and replace with deckboards. This is your only sensible option, otherwise you'll be putting your foot through it after a few wet spells.
Yes, but now you have a metal framed building, so you need to know the requirements for that. And for the route of any concealed cables, and RCD protection for sockets.
