vaillant
22 Sep 2009
Hartlepool
hi , help .changed a diverter valve for no hot water, all okay ,called back two days later not firing on hot water, microswitch not fully engaging, could it be differential
hi kevplumb , sorry i have just read my post and i didnt say it is a turbomax ,how thick is i
ye everything was fine when i left, the boiler fired first time when i put the water back on fired it in an out repeatedly no leaks this was on friday i got called back today late on, an had a quick look ,going back in the morning , the microswitch is engaging the switch just not quite enough to make the connection, yes it is a 242, i am not really sure if the diff is making im not sure i would know how to check
when you run the tap press the top of the white plastic arm if it lights and works ok
then
is there a decent scale reducer fitted i know what the water does to combis there ;)
is the flowrate and temp rise ok
the plastic arms are a swine for bending / snapping ;)
thanks for your help kev i returned this morning removed diff, cleaned it out and altered the throttle on the bottom of diverter any how she fired and i have not had a call back yet!
