DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     About CookiesCookies     SearchSearch     LoginLogin
Window re putty and painting in one day
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Search this topic :: View previous topic :: View next topic
Author Message
Boons
from United Kingdom
PostPosted: Tue Sep 29, 2009 7:13 am Reply with quote
Hi all
I will be going to a property to remove the falling out and loose putty in the window frames, re putty then repaint with gloss.
My question is what is the best 'putty' to use, assuming it will be putty, or should I use something else? Ideally needs to be quick drying stuff.
Thanks all
Back to top
 Alert Moderators
If you do not want to see this advert, click here to login or if you are new click here to join free.
Robbie uk
from United Kingdom
Thanked: 135 times
PostPosted: Tue Sep 29, 2009 10:49 am Reply with quote
If your going to use Linseed oil putty then you can paint this straight away as the oil in the putty will want to come out as it dries for some days after. If you need to paint the same day you could try using a wooden bead of the same profile, most of the DIY's will sell them, pre prime it and this can be painted when finished.
Back to top
 Alert Moderators
NatB
from United Kingdom
Thanked: 7 times
PostPosted: Fri Oct 09, 2009 6:46 pm Reply with quote
I've got a glazier re-puttying some windows for me (I couldn't achieve the finish they do so worth the couple of quid). I asked how long I would have to wait to paint them and his response was 'the quicker the better'.
Back to top
 Alert Moderators
joe-90
from United Kingdom
Thanked: 789 times
PostPosted: Fri Oct 09, 2009 7:03 pm Reply with quote
His job is to putty the glass, he obviously isn't clued up on the painting side of things.
Back to top
 Alert Moderators
joe-90
from United Kingdom
Thanked: 789 times
PostPosted: Fri Oct 09, 2009 7:04 pm Reply with quote
If I were in a hurry I'd use car body filler - I use it for endless tasks and it never lets me down. You can paint that within 15 minutes.
Back to top
 Alert Moderators
LJW61
from United Kingdom
Thanked: 63 times
PostPosted: Fri Oct 09, 2009 11:49 pm Reply with quote
You shouldnt paint the putty til its hardened-off a bit..Anything from 2 days to a month depending on the weather.. If you want an instant-permanent-paint-the-same-day fix then do as Joe says - use Isopon p38 car body filler , works a treat I do it all the time icon_wink.gif
Back to top
 Alert Moderators
NatB
from United Kingdom
Thanked: 7 times
PostPosted: Sat Oct 10, 2009 11:43 am Reply with quote
Don't deny that, was surprised myself but I would expect him to know how putty reacts. Maybe he's going to use a non oil based putty or something..will see when he comes this week.
Back to top
 Alert Moderators
RobinClay
from United Kingdom
PostPosted: Sat Mar 03, 2012 9:53 am Reply with quote
Did you mean "can't" paint straight away ? I'm confused...
Back to top
 Alert Moderators
deanibusmaximus
from United Kingdom
Thanked: 17 times
PostPosted: Sat Mar 03, 2012 11:26 am Reply with quote
You can get glazing putty in a mastic gun tube that dries in about four hours,geocel i think. Then prime with zinsser coverstain, then straight on with your topcoats,after keying of course. Remember to prime wood prior to puttying.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
Painting putty - overlap to glass? 3 180 Tue Aug 02, 2011 12:14 pm
painting new putty 3 820 Mon Oct 05, 2009 9:05 pm
painting putty 6 1460 Thu Aug 09, 2007 8:16 am
Priming & painting putty 4 7080 Tue Jan 23, 2007 12:45 pm
Chalk or putty 2 280 Wed May 12, 2010 8:11 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
Network | Advertising | Newsletter
DIY | DIY How To | @home | DIY Wiki | DIY Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
