DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     About CookiesCookies     SearchSearch     LoginLogin
Wickes £49.99 WC
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Search this topic :: View previous topic :: View next topic
Author Message
avidfan
from United Kingdom
Thanked: 3 times
PostPosted: Mon Mar 15, 2010 10:06 pm Reply with quote
Anyone fitted the above? Been asked to fit one though not keen as I've not seen one. Apparently it comes complete with seat and even fixings!
Back to top
 Alert Moderators
If you do not want to see this advert, click here to login or if you are new click here to join free.
muggles
from United Kingdom
Thanked: 517 times
PostPosted: Mon Mar 15, 2010 10:21 pm Reply with quote
Does it have the fill and flush valves included?
I suspect the following will be a good procedure to follow: When you unpack it, take the pan out and stand it on a level surface. Step back and look at it from the front. Go fetch your level and confirm that the pan really is shorter on one side than the other. Take it back to the shop. Spend ages at Wickes unpacking many pans until you find one you're happy with. Have lunch, because by now it will be lunchtime, then fit WC. Charge customer rather more than they expected due to all the arsing about. Have an early day as there's not really time to do anything else
Back to top
 Alert Moderators
tamz
from United Kingdom
Thanked: 269 times
PostPosted: Mon Mar 15, 2010 10:25 pm Reply with quote
Don't make any difference. A pan is just a pan and at £50 inc.seat, i take it cistern as well, you can bet it is shyte quality. It will still work though.
Back to top
 Alert Moderators
neds
from United Kingdom
Thanked: 27 times
PostPosted: Mon Mar 15, 2010 11:07 pm Reply with quote
I saw whole cloakroom sets for 50 notes, they are all much of a muchness. The toilets are fine of the close coupled variety but you may have fun getting the cistern and pan to seat well without leaking.
Back to top
 Alert Moderators
roguetrader
from United Kingdom
Thanked: 775 times
PostPosted: Mon Mar 15, 2010 11:50 pm Reply with quote
i bet its better quality than the ridiculous designer back to wall pan and cistern from c.p. harts that we fitted to the 'gardeners rest room' at some posh pad today. £535 + vat. what a load of s***te!
Back to top
 Alert Moderators
lifesagasman
from United Kingdom
Thanked: 33 times
PostPosted: Mon Mar 15, 2010 11:59 pm Reply with quote
cheapies often OK except for the rubbishy seat
Back to top
 Alert Moderators
gasgeezer
from United Kingdom
Thanked: 2 times
PostPosted: Tue Mar 16, 2010 5:43 am Reply with quote
Fitted one last week fantastic, cistern already fitted took 30 mins to connect no problems since fitted quality good reccommend them.Basically idiot proof
Back to top
 Alert Moderators
linkyplumb
from United Kingdom
Thanked: 135 times
PostPosted: Tue Mar 16, 2010 7:10 am Reply with quote
The only thing I have found wrong with the cheaper wc complete units, is that when the internals start to fail (constantly overflowing etc), then it is a new flush unit as you can never normally get the spares for them.
Graham
Back to top
 Alert Moderators
jono_h
from United Kingdom
Thanked: 16 times
PostPosted: Tue Mar 16, 2010 7:58 am Reply with quote
Fitted three of the B&Q equivalents. No problems with actual fitting, but have had to tweak the flush button on two when the spring became stuck.
If you're reasonably happy that you're not going to be asked to repair it for free if it develops a fault then you should be ok
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 717 times
PostPosted: Tue Mar 16, 2010 8:40 am Reply with quote
Back to top
 Alert Moderators
avidfan
from United Kingdom
Thanked: 3 times
PostPosted: Tue Mar 16, 2010 8:03 pm Reply with quote
Bit the bullet and fiited said wc today. Pleasantly supprised, not a bad unit. pan has a nice big foot so it's pretty stable and it weighs a ton. Flush and fill valves prefitted and didn't leak. As mentioned, the seats a bit flimsy and the outlet spigot could have been a tad longer. However, for fifty notes not at all bad.
Back to top
 Alert Moderators
ub7rm
from United Kingdom
Thanked: 3 times
PostPosted: Tue Mar 16, 2010 8:15 pm Reply with quote
I fitted the B&Q equivalent in my flat last year and was / am quite happy with the quality. No leaks / no hassle. Threw away the seat that came with it without even fitting it.
Back to top
 Alert Moderators
muggles
from United Kingdom
Thanked: 517 times
PostPosted: Tue Mar 16, 2010 8:16 pm Reply with quote
Sounds like I was wrong then, will have to look at them as potential suppliers for contract stuff in future...
Back to top
 Alert Moderators
tamz
from United Kingdom
Thanked: 269 times
PostPosted: Tue Mar 16, 2010 9:37 pm Reply with quote
That might be an idea icon_idea.gif Cheapest i can get is around £75 + for pan cist & seat and still a phishy plastic seat.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
Wickes toilet and pan connector 2 460 Fri Jan 15, 2010 11:48 pm
wickes heat 40 aps fault? 2 460 Fri Oct 30, 2009 8:07 am
Halstead Wickes LW50ci wont ignite 2 460 Tue Oct 06, 2009 5:35 pm
wickes rwb9.cw 2 500 Tue Dec 01, 2009 6:09 pm
Wickes Aquatronic 2 Shower 6 1180 Tue Jan 05, 2010 10:38 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
Network | Advertising | Newsletter
DIY | DIY How To | @home | DIY Wiki | DIY Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
