| Author |
Message |
Andydevon
Joined: 29 Mar 2010 Posts: 12 Location: Devon, United Kingdom
Posted: Thu Oct 28, 2010 4:25 pm |
I am having a new garage door fitted with an electric opener. As part of the electrical install is to fit at my request a garage CU to replace an old junction box with a more professional solution. The cables in the picture come through the wall from the main CU - modern with RCD etc. The large cable is for a shower and not to be disturbed. The line into the junction box is for power in the garage split 3 ways to 3 separate sockets.
[/img]
The lighting circuit is separate and fed through the Kitchen.
After the garage CU is installed and part P signed off I intend to run the cabling through conduit rather than just clipped to the joist. Is running through conduit minor work i.e. does not require signing off as well?
Basic question is, am I over engineering this? Would a better junction box be just as adequate with conduit? |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
electronicsuk
Joined: 07 May 2007 Posts: 3303 Location: Lincolnshire, United Kingdom Thanked: 273 times
Posted: Thu Oct 28, 2010 5:06 pm |
As you seem to be hinting, there's little point in installing any kind of DB here. The important thing is to ensure that the correct protection is installed back at the main consumer unit. Assuming it's 2.5mm T+E, you will likely be looking at a 16A protective device. You'll need to check on derating factors on account of moving the cables from clipped direct into conduit. |
| Back to top |
pjcomp
Joined: 22 Jun 2010 Posts: 432 Location: United Kingdom Thanked: 59 times
Posted: Thu Oct 28, 2010 5:10 pm |
Sounds like you're making it a lot neater, and from what you've said the garage CU is a bit over engineered. Sounds like the garage is integral to the house, not a separate building, so your current cabling souinds OK (assuming the three garage sockets are on a radial and not a radial spur off the ring ...). Garage door openers are usually 12V so the power requirement from them is pretty minimal, and plugging it into one of your existing sockets would probably work perfectly well.
But hey, better to be neat and over-engineered than having the sort of dog's breakfast we so often see here.
PJ |
| Back to top |
Taylortwocities
Joined: 27 Jul 2006 Posts: 10468 Location: Oxfordshire, United Kingdom Thanked: 720 times
Posted: Thu Oct 28, 2010 5:15 pm |
Does that feed to the garage come from its own mcb in the main fuseboard?
If so, what is the value of that ?
You say that there is an RCD protecting the circuit. There's no point having another one in a garage CU, as stated above, all you need is a switched FCU for the lights. |
| Back to top |
ban-all-sheds
Joined: 27 Aug 2003 Posts: 41397 Location: London, United Kingdom Thanked: 1337 times
Posted: Thu Oct 28, 2010 5:16 pm |
| Andydevon wrote: | | After the garage CU is installed and part P signed off I intend to run the cabling through conduit rather than just clipped to the joist. |
Do you mean that you intend to run new final circuits?
If so they'll need testing and will be notifiable and there's little value in an EIC and Building Regulations certificate which don't cover all of the circuits.
If you mean you're going to take the wiring, disconnect it and put it through conduit then although that's not notifiable you ought to have the electricians do it as after what is essentially a rewire of the circuits using the old cable it ought to be tested. |
| Back to top |
Andydevon
Posted: Thu Oct 28, 2010 6:07 pm |
Thanks for all the suggestions.
Yes it is an over engineered option but it will be tidy and neat. Protection is more than satisfactory at the main CU. All it will cost me is the new Garage unit & conduit & a few conduit boxes (£50 odd) and they are not charging extra on the fitting fee for the door so might as well use the fitters when there here. The door is costing an arm and a leg but is the best I could find so lets do a proper job. (£50 odd does not include bacon butties & mugs of tea of course)
I take on board the suggestion to test all the cables and conduit beforehand this does make a lot of sense. I do not intend adding any more sockets / spurs etc. after this so it will be a test of what is there.
Thanks for the prompt responses |
| Back to top |
securespark
Joined: 11 Jan 2004 Posts: 22533 Location: Cheshire, United Kingdom Thanked: 306 times
Posted: Thu Oct 28, 2010 11:20 pm |
Am I seeing that JB right?
Is that the JB for the shower?
If so, is the feed for the garage spliced off it? |
| Back to top |
1john
Joined: 03 Oct 2009 Posts: 3336 Location: West Glamorgan, United Kingdom Thanked: 336 times
Posted: Fri Oct 29, 2010 7:52 am |
I dont think so fella, the 6mm seems to pass the junction box and is propping the wayrock up off of the joist above. |
| Back to top |
Andydevon
Posted: Fri Oct 29, 2010 11:00 am |
The shower cable is separate to the power cable they just come through the same hole in the wall. Yes it does need sorting and the area above the cable clearing. |
| Back to top |
