DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     About CookiesCookies     SearchSearch     LoginLogin
Bathroom Project (Well Needed Aswell) LoL
Goto page Previous  1, 2, 3  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Your Projects
Search this topic :: View previous topic :: View next topic
Author Message
iamlee2002
from United Kingdom
Thanked: 3 times
PostPosted: Fri Mar 04, 2011 8:52 pm Reply with quote
hi sixeighth we went for this:
http://www.bellabathrooms.co.uk/boaz-thermostatic-mixer-shower.html
works a treat, we dont have very high water pressure in our house but this shower even with low pressure is very powerful. Would deffinitly recommend this to you. If you getting conceald shower unit you need to bury it in quite a few inches but once done looks good icon_smile.gif
Back to top
 Alert Moderators
If you do not want to see this advert, click here to login or if you are new click here to join free.
sixeighth
from United Kingdom
Thanked: 2 times
PostPosted: Fri Mar 04, 2011 9:05 pm Reply with quote
Thanks Lee.
That's the style we're after but with a 3-way diverter (not too many of them about). We've been looking at separate heads, like the one you have, but would like to make sure we'll end up with a decent shower. We'd prefer concealed as well.
Well done on completing your project by the way - you must have saved a fair bit by doing the work yourself.
Back to top
 Alert Moderators
iamlee2002
from United Kingdom
Thanked: 3 times
PostPosted: Mon Mar 21, 2011 9:15 pm Reply with quote
Next project Build a garage, clear rubbish first icon_smile.gif any advice greatly appreciated
Back to top
 Alert Moderators
cliffwright
from United Kingdom
PostPosted: Mon May 09, 2011 11:11 am Reply with quote
1 question though . . . your room looks roughly the same size as ours & I'm trying to decide which towel radiator to go for . . . how did you choose this radiator in terms of heating output? All the towel rads I can see seem to give out less heat than a BTU calculator suggests I need . . .
How do you find yours heating wise?
Cheers
Cliff
Back to top
 Alert Moderators
iamlee2002
from United Kingdom
Thanked: 3 times
PostPosted: Sat May 14, 2011 5:00 pm Reply with quote
with regards to towel rail just choose it due to it been on offer in screwfix, its a decent size had it half price. It does get scortching hot but i agree a normal double convector rad produces alot more heat. But with the bathroom being insullated all over, the radiator produces more than enough to keep the room upto temp icon_smile.gif
Lee
Back to top
 Alert Moderators
iamlee2002
from United Kingdom
Thanked: 3 times
PostPosted: Mon Dec 12, 2011 7:36 am Reply with quote
thx buddy glad to finish it in the end though lol one bit of advice though, i wouldnt do it in the winter time again lol cutting tiles out the garden... was -5 or so after each cut had to heat my hands up lol nm worth it in the end icon_smile.gif good luck on urs m8
Back to top
 Alert Moderators
nightstalker
from United Kingdom
Thanked: 1 time
PostPosted: Sat Dec 31, 2011 3:36 pm Reply with quote
Amazing mate. looks fresh, clean and modern.
I have been thinking about replacing our bathroom for a few years now, unfortunately, the bathroom was built into the house (Victorian terraced) and there isn't any realistic way we can remove and replace the bath (I can get it out but cutting it in to pieces but obviously cannot put a new one in the same way haha) so I have convinced the mrs that we only need a shower (just waiting till the daughter is a little older and that will be done, probably 2014)
Back to top
 Alert Moderators
keen2learn
from United Kingdom
Thanked: 4 times
PostPosted: Mon Jan 02, 2012 10:53 am Reply with quote
I have what may seem like a daft question is 50mm celotex overkill my concern would be shrinking the room 50mm celotex 12.5mm plasterboard then tiles thats what seems to me a lot of wasted space. I can only assume your house has no cavity so no ability for cavity wall insulation?
Back to top
 Alert Moderators
Alarm
from United Kingdom
Thanked: 527 times
PostPosted: Mon Jan 02, 2012 6:34 pm Reply with quote
I`d get that PIR out of the bathroom or get the thing well sealed up.
Even so it wont like it.
Back to top
 Alert Moderators
BigRobCanUFixIt
from United Kingdom
Thanked: 26 times
PostPosted: Tue Jan 03, 2012 3:01 pm Reply with quote
Nice job there.
Back to top
 Alert Moderators
iamlee2002
from United Kingdom
Thanked: 3 times
PostPosted: Thu Jan 05, 2012 11:35 am Reply with quote
that pir is designed for the bathroom m8 paid alot more than the bog standard ones, in a year havent had any issues icon_smile.gif
keen2learn, my bathroom has cavity wall insulation but it was done when it first came out its v poor cavity wall insulation was freezing, since putting the celotex its a sauna icon_smile.gif
the rest of my house is the old stone so i have to get round to insulating that the same way. It is alot of room to sacrifice but saving on the heating bills and being warm is the plus side icon_smile.gif
Back to top
 Alert Moderators
keen2learn
from United Kingdom
Thanked: 4 times
PostPosted: Thu Jan 05, 2012 10:06 pm Reply with quote
Iamlee22
if you put it like that its a sacrafice that has bigger benefits
Thanks for your reply
Back to top
 Alert Moderators
mole81
from United Kingdom
PostPosted: Sun Feb 05, 2012 9:41 am Reply with quote
Hi, looks good!
what plasterboard have you used there? did it need a skim before putting the tiles on?
Back to top
 Alert Moderators
iamlee2002
from United Kingdom
Thanked: 3 times
PostPosted: Thu Feb 23, 2012 6:33 am Reply with quote
Hi there, just used M/R boards in less wet areas, then where the bath is etc used cement based backer boards. No need to skim if tiling buddy
Back to top
 Alert Moderators
skotl
from United Kingdom
Thanked: 37 times
PostPosted: Fri Feb 24, 2012 12:42 am Reply with quote
Great job, Lee, well done!
I never think to take the "before" pictures but they tell so much more of a story. I don't even think I'd have bought the house had I seen the before pics, so well done for having the vision, and for carrying it through icon_lol.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Your Projects All times are GMT
Page 2 of 3
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
DIY B&Q Kitchen Project (Some Advice needed) 19 11660 Sun Jan 25, 2009 11:53 pm
Huge Fireplace help needed 6 360 Sun Apr 28, 2013 12:14 am
Bedroom design - help needed 9 840 Tue Jan 17, 2012 1:41 pm
kitchen refot - help needed 2 480 Tue Nov 29, 2011 11:46 pm
Brilliant Idea Needed! (with Pics) 8 2760 Mon Mar 10, 2008 5:15 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
Network | Advertising | Newsletter
DIY | DIY How To | @home | DIY Wiki | DIY Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
