DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     About CookiesCookies     SearchSearch     LoginLogin
Gravity fed heating
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Search this topic :: View previous topic :: View next topic
Author Message
smashit
from Romania
PostPosted: Sat Jul 02, 2011 6:23 pm Reply with quote
Hello again good Forum. icon_biggrin.gif well its been a year since i was on here for advice icon_redface.gif ....anyhow i need advice on a central heating system......Firstly i have just bought a single storey cottage in the Mountains of Romania now here is where the problem is NO ELECTRIC.......so i want to install a woodburner with back boiler and 3 radiators (no hot water tank) icon_eek.gif so what i need to know is can i install this with no pump....the header tank would be directly above the fire some 7ft ....am i also correct in thinking i would need to use 22mm copper throughout the system.....and how reliable as a system is it icon_question.gif thanks in advance
Back to top
 Alert Moderators
If you do not want to see this advert, click here to login or if you are new click here to join free.
Servotech
from United Kingdom
Thanked: 38 times
PostPosted: Sat Jul 02, 2011 7:11 pm Reply with quote
It's possible, but things have now moved on from the days when gravity ch heating was
installed.
Things you will need -
22mm pipes all round - yes no problem.
x3 3/4" tapped out radiators - very hard to get hold of these days.
x6 3/4" - radiator valves - again very hard to find.
Requirements for gravity circulation -
Header tank at least 1m above the highest radiator.
A rise (or level at least) on all flow pipes leading to each radiator.
A fall (or level at least) on all return pipes from radiators returning to boiler.
Though you are allowed a small dip on the return it's something like 1/10th of the circulating height (making a underfloor return possible).
If you can source the materials and meet all the requirements then it will work very well forever more (nothing to go wrong)!
Good luck,
servotech,
Back to top
 Alert Moderators
smashit
from Romania
PostPosted: Sat Jul 02, 2011 7:57 pm Reply with quote
installed.
Good luck,
servotech,
Many thanks for the swift reply, may i ask would any benefit be gained by having the hot send pipes in the loft (lagged) and dropping down to each rad ? the cold return at floor level ?
Back to top
 Alert Moderators
Servotech
from United Kingdom
Thanked: 38 times
PostPosted: Sun Jul 03, 2011 5:35 am Reply with quote
Sounds like you're using the old one pipe system.
A good old fashioned way of doing it and you can use the allowed (1/10th of circulating height) dipped return to connect the return at floor level up to the boiler.
The Expansion/feed tank will need to be (at least 1m) above the heating flow in the loft and the expansion pipe taken from the flow at the highest point will also act as the vent.
Use straight not angled radiator valves on the flow to each radiator.
A valve on the radiators return is not really needed on this system.
It will all work fine, the only problem is sourcing the materials in 2011. There's no demand so no-one bothers to manufacture them!
Back to top
The following user says thank you to Servotech for this useful post:
smashit (3 Jul 2011)
 Alert Moderators
smashit
from Romania
PostPosted: Sun Jul 03, 2011 9:18 am Reply with quote
I was pondering on the one pipe system as i will be adding antifreeze to it for when the property is left alone.....Its good to know that the one pipe system works......as far as getting the fittings that is no problem in Romania (they are not as modern as us) Lots of good old second hand school type rads around for about @ 1 each LOL.......I am building a Russian masonry fire (why we dont have them in UK i dont know) but inside i will fit two boiler jackets to supply the 3 rads only........Can you reduce down to 15mm at the Rads or will that reduce the flow too much.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3487 times
PostPosted: Sun Jul 03, 2011 9:42 am Reply with quote
Perhaps I am wrong and if so some of the old boys will correct me.
But this is a SINGLE story cottage!
I dont think there is enough vertical height to get any significant gravity flow going with normally used pipe sizes.
If you calculate the gravity head in a two story building with a 10 C delta T then its more like just 0.1m
Back to top
 Alert Moderators
smashit
from Romania
PostPosted: Sun Jul 03, 2011 9:54 am Reply with quote
Hello
thanks for your reply.....It is a cottage and i have a max of 2.5 m up from the boiler poss 3m max is that enough ?
thanks again and sorry to be a pain but i need to get it right first time
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 316 times
PostPosted: Sun Jul 03, 2011 3:20 pm Reply with quote
If you have 1m head above the flow / vent pipe in the loft it will be fine. If the rads are not too large 15mmm will be ok.
Use swept tees for the drops if you can.
Back to top
 Alert Moderators
Servotech
from United Kingdom
Thanked: 38 times
PostPosted: Sun Jul 03, 2011 6:04 pm Reply with quote
I was pondering on the one pipe system as i will be adding antifreeze to it for when the property is left alone.....Its good to know that the one pipe system works......as far as getting the fittings that is no problem in Romania (they are not as modern as us) Lots of good old second hand school type rads around for about @ 1 each LOL.......I am building a Russian masonry fire (why we dont have them in UK i dont know) but inside i will fit two boiler jackets to supply the 3 rads only........Can you reduce down to 15mm at the Rads or will that reduce the flow too much.[/quote]
1 EACH!!! That's really cheap and they sound just the job.
I cannot recommend reducing down to 15mm to the rads for the reason that you have mentioned - gravity needs large pipes and no restrictions (hence the 22mm radiator valves I've recommended) going down to 15mm would be asking a lot.
On the other hand increasing the size of the heating main to 28mm would be a plus.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
Gravity Fed Heating 5 300 Sat May 02, 2009 6:03 pm
Installation of gravity fed heating system from a woodburner 5 500 Mon Mar 30, 2009 11:05 pm
Pumped Heating Gravity HW Prob 2 420 Tue Mar 27, 2007 11:20 pm
cold bathroom radiator (gravity fed/central heating 2 40 Mon Oct 22, 2012 12:41 pm
Gravity heating 4 120 Sat Oct 01, 2011 9:23 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
Network | Advertising | Newsletter
DIY | DIY How To | @home | DIY Wiki | DIY Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
