The patterned side should face the inside of the DG unit, and the patterned glass should be on the inside of the building. I assume this is so the pattern doesn't attract dirt, and to make the glass easier to clean by facing a flat glass face to the outside (the patterned glass may have slight indentations on the unpatterned side).
