DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Installing an additional light switch
This topic originated from the How to page called Installing a power socket
Click here to return to the page called Installing a power socket.
  View previous topic :: View next topic
Author Message
bridgecottager
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 02, 2007 6:08 am    Post Subject:
Reply with quote Thanks
I want to add an additional light switch to an existing lighting circuit.
My garage has a single light in the centre, which is operated by an existing light switch on the wall by the garage door. I want to install an additional light switch by the access door to the house, which, of course, is in the far corner of the garage to the existing switch, so I can turn the light off when leaving the garage, rather than using the existing switch and then breaking my neck when trying to find my way back to the access door in the dark!
Do I have to change the existing ceiling rose to accept wiring from a second switch? Can I introduce wiring from a second switch to the exisitng rose? or do I have to connect the new switch all the way around the garage to the exisitng switch?
Could someone kindly give me some guidance.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Sun Sep 02, 2007 7:39 am    Post Subject:
All you need to d is run a length of 3core and earth cable from the existing switch to where you want the additional switch.
Have a look in the FAQ under two way lighting. Its all explained there.
__________________
TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Sun Sep 02, 2007 12:24 pm    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Installing an additional wall light 3 200 Tue Oct 28, 2008 7:02 pm
Installing additional sockets 22 960 Tue Jan 08, 2008 8:25 pm
Installing additional exterior lights 14 880 Mon Mar 12, 2007 9:59 pm
additional light to a switch replacing 1 gang with two. 5 320 Mon Nov 03, 2008 7:55 pm
3-way light switch with additional 1-way required 10 580 Mon Jan 09, 2006 3:38 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
