DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
help - variable shower/water temp
This topic originated from the How to page called Choosing a shower
Click here to return to the page called Choosing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
amleca
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 04, 2007 8:27 am    Post Subject:
Reply with quote Thanks
Please help! I live on the 1st floor, have a Halstead Finest Gold combi boiler and a shower that feeds off this (not electric or pump). The water pressure isn't great has been measure and is just above the legal minimum - only one mains pipe feeding the block of four flats though. When running hot water for the shower, it takes a while to get going then sometimes varies between hot and cold. This seems to happen with baths as well, tho normally when the tap is on full. It does not necessarily seem to be at 'peak' hours when others might be having showers (but I can't say for certain!). I have had a gas safety check on the boiler... heating engineers have said it is not the best boiler but is ok (tho it sometimes loses pressure and needs topping up). The pressure from other taps seems ok but drops off sometimes, I think when other flats are using the water.
Help - how on earth do I tackle this? Will a shower with a pump work - or a thermostatic shower??? Or could it be a boiler problem? No one seems to be able to tell me. I really don't have much of a budget and don't want to spend money fixing the wrong problem!
Any advice gratefully received!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Tue Sep 04, 2007 11:21 am    Post Subject:
Re: help - variable shower/water temp
Sounds as if you need to get an engineer to sort your DHW.
__________________
85 weeks without smoking!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Variable Shower temperature - HELP! 10 840 Thu Aug 17, 2006 10:47 am
Radiator variable heat 4 2640 Wed Dec 17, 2003 2:27 pm
Heating pump - Variable or 3 speed? 3 140 Tue Sep 22, 2009 6:29 pm
Baxi Combi 105 HE ch variable 12 2520 Sat Jun 30, 2007 5:50 pm
Variable boiler pressure 2 2300 Wed Sep 14, 2005 1:22 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
