DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Plumbing.
This topic originated from the How to page called Fitting an electric shower
Click here to return to the page called Fitting an electric shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
garter09
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 07, 2007 8:18 pm    Post Subject:
Plumbing.
Reply with quote Thanks
Hi, Can anyone help me, When i put my hot water on to have a bath when i start running the hot water after about 2 or 3 mins i start to get a very bad smell in my property, It is a very strong smell it only happens with the hot water. Pls any idea how i may sort this or what it could be.
Back to top
 Alert Moderators
Moderator 9
Moderator Comment
Posted: Sat Sep 08, 2007 12:01 am    Comment:
Hi and welcome to the forum.
I have moved this post over to plumbing and left a link to it in electrics as our plumbing friends may also be able to help.
If you don't want to see this advert, click here to login or if you are new click here to join free.
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Fri Sep 07, 2007 8:26 pm    Post Subject:
Well, a good start would be to let us know how the water is heated!
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 22 times
How is the water heated. Gas or electric.
Either way a lot of smell is a sign that something is seriously wrong and needs to be checked.
Tell us more and preferably do not run the bath until you know it is safe.
Electric and it could be a cable overheating with a risk of fire.
Gas and it could be combustion products in the house. That can be lethal as in carbon monoxide poisoning
Back to top
 Alert Moderators
garter09
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 07, 2007 8:34 pm    Post Subject:
Hi There.
The water is heated by electric, All i can say it smell sometimes like wastage, I have tryed draining to water tank to see if it may of been coming from there but i could not see anything.
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Fri Sep 07, 2007 8:36 pm    Post Subject:
Heated by Electric.....
Immersion heater?
Instantaneous water heater?
Elec boiler with wet system?
A little more info is needed TBH...
Back to top
 Alert Moderators
garter09
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 07, 2007 8:39 pm    Post Subject:
Sorry
It is done with a Immersion heater, I don't really know much about these things sorry.
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Fri Sep 07, 2007 8:40 pm    Post Subject:
So when you turn the immsersion on you get a smell? Not when you turn a tap on?
Back to top
 Alert Moderators
garter09
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 07, 2007 8:44 pm    Post Subject:
Hi
After we have heated up the tank with hot water, the go to run a bath of water after about 2 or 3 mins the smell starts, It does not smell if i fill the sinks only when i do the bath.
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Fri Sep 07, 2007 9:24 pm    Post Subject:
So it sounds like that u get the smell when some hot water is run off and the immersion heater kicks in??
Does it smell sort of fishy?
It may well be a loose connection in the immersion heater wiring, or one of the switches in the circuit. Turn the power off and have a look in the isolation switch and under the cover of the immersion itself. you may find a melted wire due to a loose connection.
Do let us know if u find anything..
__________________
TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sat Sep 08, 2007 12:18 am    Post Subject:
Could be something resting against the pipe? When you run the hot water through it is cooking? Running the sink probably won't take as long so you may not notice it the same.
Back to top
 Alert Moderators
sooey
from United Kingdom
Thanked: 12 times
PostPosted: Sat Sep 08, 2007 12:54 am    Post Subject:
Cmon lads you're not thinking laterally here, now op two or three minutes after you start running the bath but not when running anything else, is that right ? If so how often do you change your undies?
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Sat Sep 08, 2007 5:15 pm    Post Subject:
What I am suggesting is that, if its a loose connx, then the immersion will be running for a while - maybe long enough for the wire to heat up & start smelling. With a sinkful the immersion isnt on for long so the wire doesnt get to meltdown.
Would be good to get some feedback from the OP. I wait, with bated breath.
__________________
TTC
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Plumbing - Water venting into F & E tank 2 300 Tue Mar 18, 2008 11:40 am
Plumbing under sink to remove noise from plug...? 2 360 Thu Mar 27, 2008 5:20 pm
plumbing 6 240 Mon Mar 17, 2008 3:56 pm
PLUMBING PROBLEM! 5 220 Sun Mar 16, 2008 4:06 pm
plumbing and central heating 3 340 Fri Mar 14, 2008 5:06 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
