DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Replacing kitchen taps
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
gairloch
from United Kingdom
PostPosted: Wed Sep 12, 2007 6:48 pm Reply with quote
Hi folks,
I have a small question regarding replacing some taps, it's probably just me over complicating a fairly simple job, but I just need a little reassurance from the experts!
I have a mixer tap in the kitchen sink, beneath which, two copper pipes enter it, 15mm. I have a new tap to fit, which came complete with braided hoses for installation. What I propose to do seems fairly straight forward, in that i want to fit the new tap, then the hoses, then each hose into an isolator valve and then onto the existing copper pipe. The valves have brass olives to compress to the copper pipe at the other end, but connecting the hose to the valve, has me thinking. It's the same thread, and the braided hose has a rubber seal inside it, so I assume that when i remove the nut and olive from the opposite end of the valve, I can just tighten the hose right onto it. Is that right, or am I missing something, or am I as I suspected, looking for a problem where none exists, and over complicating the job?
I have offered a couple of pics to show the components that i have. Many thanks for your advice.
[/img]
Back to top
 Alert Moderators
wiggikins
from United Kingdom
Thanked: 13 times
PostPosted: Wed Sep 12, 2007 8:47 pm Reply with quote
You are quite right in surmising that you are creating a problem which does not exist, However take care not to over tighten the hoses into the tap body,hand tight should suffice . Likewise with the connection to the isolating valvas, hand tight then half a turn is usually enough.
Back to top
 Alert Moderators
gairloch
from United Kingdom
PostPosted: Wed Sep 12, 2007 8:55 pm Reply with quote
Thnaks very much for the advice, and the tips. It's appreciated icon_biggrin.gif
Back to top
 Alert Moderators
gairloch
from United Kingdom
PostPosted: Sat Sep 15, 2007 12:51 pm Reply with quote
Hi again folks,
Well success! I have fitted the new mixer tap!
Unfortunately it seems to be very noisy. When i turn the single lever to hot, water flows etc, and no exceesive noise, when its turned fully to cold, a bit noiser, but i guess maybe due to higher pressure, but it's definetly not excessive. However when the tap is turned toward the centre, so that both hot and cold water flow, then it gets really noisy, no banging or anything, just very loud water "rushing noise". A lot louder than my previous tap. Could this be anything really to do with the installation, or is it just probably the type of tap itself? Ive included a picture of the tap itself.
Many thanks
[/img]
Back to top
 Alert Moderators
hi-spec plumbing heating
from United Kingdom
PostPosted: Sat Sep 15, 2007 1:48 pm Reply with quote
shut the iso valve slightly
Back to top
 Alert Moderators
gairloch
from United Kingdom
PostPosted: Sat Sep 15, 2007 6:02 pm Reply with quote
I have tried that, and it did have an effect, in as much as it stopped the noise when cold only running, but the noise is still 75% or so there when tap in center and running hot and cold. icon_cry.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Replacing kitchen taps: backnuts glued in place. 5 120 Wed Dec 29, 2010 10:54 am
HELP, Replacing Kitchen taps - Collet joints. 8 1000 Tue Jan 02, 2007 4:16 pm
Help with replacing kitchen taps 4 1820 Sun Apr 24, 2005 11:35 am
kitchen taps 5 60 Fri Jun 10, 2011 6:47 pm
NEW KITCHEN SINK & TAPS = REDUCED HOT WATER FLOW 43 8220 Thu Dec 14, 2006 11:40 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
