I know it's a subject that's been covered a lot (and I've read all the FAQs) but some of the previous posts seem to conflict and/or don't match my boilder setup, so I'd really appreciate it if you could give me some pointers on how to remove a rad for decorating then put it back without blowing my house up!.
As I understand it I need to do the following:
TO REMOVE RAD (Without Draining Whole System):
- Close both valves on ALL rads (Is this excessive?)
- Close all valves under my Gloworm Combi-boilder(inc Gas?)
- Turn off boiler
- Remove and drain target rad (which will depressurize the system)
- Bleed all other rads before system startup (top floor down)
- Open valves under boiler
- Turn on boiler
- Top-up using filler loop (under boiler)
- Open all other rad valves (bottom floor up)
TO REPLACE RAD AFTER DECORATING
- Repeat all of the above
Does that sound about right or am I a danger to me and my neighbours?
Many thanks.
- Turn off boiler
- Turn on boiler
Many thanks.
