DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Replacing 2-Gang Switch with Metal Dimmer
This topic originated from the How to page called Replacing a one way light switch
Click here to return to the page called Replacing a one way light switch.
  View previous topic :: View next topic
Author Message
samwolf
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 16, 2007 9:51 am    Post Subject:
Reply with quote Thanks
Hi all,
Have just moved into a new build (3 months old) and want to replace plastic 2-gang switch (I think that's the correct term - 2 switches on 1 wall plate controlling 2 separate fittings?) with a double rotary metal dimmer.
Current backing plate is plastic, so no earth wiring, and wiring to the switch is currently 2 brown wires(presumably live and switched live) to each side of the switch (1 to com, and 1 to L1, and there is also an empty L2 on each side), then with a bridge of brown wire joining the two L1's together. However there are also 4 blue wires and 4 earth wires going into a terminal block (with nothing out of the other side).
Firstly - if I match the brown wiring on the new dimmer to the existing wiring, will this work? (total wattage per light fitting is only 120W, so within dimmer rating).
Secondly - I will need the earth for the new metal switch plate - presumably I can just wire to the opposite side of the one into the terminal block, but how do I check that it's actually connected to an earth block at the other end of the circuit?
Apologies - new to this - if you need more clarity let me know!
Sam.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
jj4091
from United Kingdom
Thanked: 8 times
PostPosted: Sun Sep 16, 2007 10:22 am    Post Subject:
Yes you can do it as you propose, if it is a new build I would be amazed if the cpc's are not connected to earth but you can prove it by measuring between live & earth & you should read 230/240v AC approx.
Back to top
 Alert Moderators
samwolf
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 18, 2007 7:31 pm    Post Subject:
Great - thanks - will let you know if I have any trouble.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Installing a metal 1 gang light switch 3 440 Sat Dec 29, 2007 3:46 pm
Metal 2 Gang light switch not earthing correctly? 16 860 Sun Sep 30, 2007 6:15 pm
Replacing Plastic Light Swtich with Metal Switch 2 480 Thu Nov 18, 2004 4:55 pm
Replacing existing Ring Main Sockets with Metal Ones 16 960 Tue Apr 03, 2007 8:10 am
replacing a plastic swich with a metal one... 11 260 Tue Sep 02, 2008 6:22 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
