LT101
Joined: 16 Sep 2007 Posts: 4 Location: London, United Kingdom Thanked: 0 times
Posted: Sun Sep 16, 2007 10:37 pm Post Subject: ceiling cabling |
heya
i am planing to fit a extractor fan onto a existing light. i am all happy with the location of the fan and the connections etc but the physical wiring has me a lil confused
is running cableing above the ceiling simelar to running them underfloor? ie attached 50mm high on joists.
i guess i am trying to conserve the ceiling if i can. i would ideally like to cut a groove and add a conduit but am not sure if that is acceptable in a celing
thx for any help  |
Softus
Joined: 21 Oct 2004 Posts: 19532 Location: United Kingdom Thanked: 6 times
Posted: Mon Sep 17, 2007 12:28 am Post Subject: |
Er, is this a top floor room? If so, do you have access to the ceiling void from above, e.g. in a loft space? |
LT101
Posted: Mon Sep 17, 2007 9:43 am Post Subject: |
no, its a room in a basement flat, so there is no overhead access. The neighbour upstairs has a tiled floor as well so i cant get thru there either |
Softus
Posted: Mon Sep 17, 2007 12:15 pm Post Subject: |
Putting the cable into conduit will just reduce its current carrying capacity. Can't you just draw it across where you need it to go and leave it at that? |
LT101
Posted: Mon Sep 17, 2007 5:51 pm Post Subject: |
how do u mean draw it across? like just feed it over the ceiling
that certainly seems the easiest way
thx for ur help  |
Softus
LT101
