DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Britony 80se hydraulic block
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
riverside443
from United Kingdom
PostPosted: Mon Sep 24, 2007 10:21 pm Reply with quote
I have a small water leak that seems to be coming from the join between the diaphragm housing/ motor and the main body of the R/H (3 way valve) hydraulic block. Leak is only slight, about 1 drop every few minutes and the system works ok. Hopefully just an O ring? Is this a problem area on these boilers. It is approx 7 years old and been totally reliable up till now, cheers.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2522 times
PostPosted: Mon Sep 24, 2007 10:47 pm Reply with quote
I dont recall any diaphragm in these boilers.
Most components are sealed with "O" rings and are surprisingly reliable and only VERY rarely give any problem as long as the joint has not been abused.
Tony
Back to top
 Alert Moderators
chrishutt
from St. Pierre and Miquelon
Thanked: 15 times
PostPosted: Tue Sep 25, 2007 6:40 am Reply with quote
Lucky you! Expect the PCB to fail (£150!) any time soon, plus the pressure release valves are prone to leak.
As for your leak, it's from the small o ring in the base of the diaphragm housing. You could dismantle and just tighten the brass screw that holds the o ring in place. However a new diaphragm kit is only £6 and includes all the components - o ring, screw, diaphragm and bearing plate. I doubt whether you'll find an o ring supplied separately.
Note to Tony - he's talking about the SE model.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Riello Hydraulic Jack replacement 4 380 Thu Oct 07, 2010 9:25 am
britony combi 80se burner goes on and off 10 820 Tue Mar 28, 2006 8:26 pm
Britony Combi 80se - Flashing 40 80 error 9 100 Sat Mar 31, 2012 8:32 am
Chaffoteaux Britony Combi 80SE - Low Pressure/PRV 3 520 Sat Jan 30, 2010 1:41 pm
Sani-block 11 620 Fri Jan 30, 2009 7:23 pm
DIYnot
