First post, mainly in desperation!!
We recently re-did the bathroom, with my Wife and I doing the tiling and painting, with the plumbing left to a local Council plumber doing a "weekend" job.
Well we've had the shower in for a month now (a 3/4" Dual Control Thermostatic Shower Valve, MFI Victorian Looking thing). I set the temp stops at 38 deg from the off and everything has been running fine, until a week ago.....
We have a Combi Boiler (hence why we went with the mixer rather than electric)
Not sure what changed but the temp at the Shower head has dropped.
We've upped the Boiler HW to max; adjusted the Shower Valve to as hot as it'll go; I've reduced the cold water flow to the Shower by half turning in the isolation tap on the Shower's CW supply. By not turning the flow on as much at the shower as we previously could it can run at an OK temperature. Still doesn't run as well as it used to.
I have no idea as to what's changed.
Hope someone here can help.
Quite annoying as it's only been in over a month.
Did coincide with the first cold snap, could it just be heat losses in the pipework?
Thanks in advance,
Niall
Thanks in advance,
Niall
