DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Replacing Extractor Fan
This topic originated from the How to page called Installing wiring for an extractor fan
Click here to return to the page called Installing wiring for an extractor fan.
  View previous topic :: View next topic
Author Message
Confusedlancs
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 27, 2007 2:05 pm    Post Subject:
Reply with quote Thanks
The pull switch in my shower room operates the light and the extractor fan.
The fan has packed up and I have bought a replacement; Vent Axia Silhouette 100T.
The problem is with the wiring. The old fan connections consisted of 2 Red wires,1 black,1 blue 1 yellow and the earth.
The new fan which is double insulated requires 3 connections L; N and Ls. I need advice on which wires to connect and what to do with the unused wires
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Thu Sep 27, 2007 2:29 pm    Post Subject:
Ok, what wires went where on the old fan. You did make a note of it, didnt you icon_smile.gif
How many cables have you got going into the fan?
__________________
TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Thu Sep 27, 2007 3:53 pm    Post Subject:
what is the wiring at the light like?
what is the wiring at the switch like?
Back to top
 Alert Moderators
Confusedlancs
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 27, 2007 3:57 pm    Post Subject:
Thank you TTC for your fast response.
I tried to make a note whilst the fan was in situ and I also took a photograph. Even with these I am not absolutley clear.
However the old fan had a terminal block with five connections and looking at it from left to right I see the following:
Connection 1 = Yellow wire from Main cable
Connection 2 = Black wire from fan
Connection 3 = Black wire from fan
Connection 4 = Blue wire from main cable and I think also the black wire from main cable. (Not Clear)
Connection 5 = Two red wires from main cable
Does this make sense
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Thu Sep 27, 2007 4:05 pm    Post Subject:
Based on what you have stated and some educated guesswork I suspect the following is correct
blue and black-->N
reds-->L
yellow-->Ls
all earths (I suspect you have two seperate earth wires running down the same sleeve) connected together with a peice of terminal block
Back to top
 Alert Moderators
Confusedlancs
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 27, 2007 4:39 pm    Post Subject:
Thanks a lot I will proceed as you suggest.
This is my first venture into this kind of forum and I'm impressed
Best Wishes
Notsoconfused
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Upgrading / replacing shower extractor fan 9 1720 Tue Aug 28, 2007 7:29 pm
Replacing existing bathroom extractor fan 6 380 Sat Nov 08, 2008 7:22 pm
Replacing Bathroom Extractor Fan 7 960 Wed Jan 14, 2004 10:28 pm
Replacing a bathroom extractor fan 15 480 Tue Jul 21, 2009 12:25 am
Replacing an extractor fan 3 640 Sun Apr 09, 2006 3:00 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
