hello we have just had the above gas boiler installed and initially the room thermostat worked in reverse ie turning it down bought the system on.
now i am a bit confused as to how this system should work.
The boiler has a control knob to set the radiator temperature which i have set to 65c all the radiators except the one in the hall have thermostatic valves the one in the hall does not and also located in the hall is a room thermostat the combination of these three different temperature controls seems to confuse the boiler and it still appears that the room stat has to be turned up to lower the temperature.
do i need a room stat at all by which i mean should i fit a thermostatic valve to the hall radiator and take the room stat out?
regards
regards
