DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Radiator leaks when turned off
This topic originated from the How to page called Fixing a leaking radiator
Click here to return to the page called Fixing a leaking radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
helenj
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 02, 2007 9:20 am    Post Subject:
Reply with quote Thanks
Hi, we moved into our house earlier this year so don't know if this is an old or new problem!
Basically, there are 2 radiators in the house which leak when they're turned off. When they're on full there's no problem at all, but leak quite badly from one of the valves when we turn them down.
Does anybody know why this might be, and how we might go about fixing it? Thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
John M
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 02, 2007 9:32 am    Post Subject:
Dickky valves ........ For the price of them, it might be a idea to have them changed icon_lol.gif
Back to top
 Alert Moderators
helenj
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 02, 2007 9:49 am    Post Subject:
Thanks John, is this something we can do ourselves? Is it relatively simple?
Back to top
 Alert Moderators
emphasis303
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 02, 2007 4:46 am    Post Subject:
From experience I would suggest actually seeing it done first time round, it is really simple but its best to see it being done as I think you dont quite understand just from words.
If you do get someone they will probably charge u for having to drain the system then bleed all the other rads in the house which is more time consuming, but if u have only one then shouldnt take too long, maybe 30mins for two rads max.
Not sure on price, wouldnt say more then £100 and thats with an expensive plumber.
Just ask around near u, im a diyer and if someone asked to change valves i wouldnt charge more then £30 labour for what ur describing.
Back to top
 Alert Moderators
The Baker
from United Kingdom
Thanked: 1 time
PostPosted: Sun Dec 02, 2007 8:39 am    Post Subject:
Didespitempharsis303.s optimism there are several points you may wish to take on board before you "do it your self".
If its a sealed system the "refill and bleed" procedure can be relatively simple.
With an open vent system the refill and bleed time can vary, I have carried out repairs to two seemingly identical houses only three doors apart on a newish estate up hear in the North West.
Both were open vent.
One took three quarters of an hour whilst the other took over two and a half hours due to an air lock.
Also the time taken to remove the existing (faulty?) valve will depend on how difficult it is to remove, I carry various tools in my van, one of which is a set of 18" stillsons that are some times needed to persuade a reluctant valve to leave the radiator.
Be careful you don't end up pulling the rad off the wall.
Before you embark on your valve changing exercise consider the time of year and the reason for considering a change of valve.
But first the valve, have you considered leaving the valves in the "on" position till the spring?
Is the heating system ok apart from these two valves?
Would it be better value for money to change all of the valves when the system is drained down?
Better than that, how about thermostatic radiator valves which would give automatic temperature control of individual rooms when the central heating is on.
What is the cause of the leaking valve, is it the condition of the system water, are these leaks a fortent of a bigger problem that would be spotted by a bloke or bloke-ett that has expierience of these things.
I am not trying to put you off having a go, thats how I learned most of my skills (aided by making use of the public library,s technical literiture section)
My main concern is that you embark upon a well intentioned adventure at this the busiest time in the heating system repairs calender, which could mean that will mean you have difficulty obtaining proffessional help if things go wrong.
As emphasis303 states, its easier once you have seen it done as you wll expeirience first hand the problems that can crop up. (and they do)
My advice would be to leave the valves fully on till the spring when you can take your time with none of the "my Mothers coming for Christmas Dinner and there,s no heating" remarks from those in doors, why risk a DIY disaster this side of Christmas.
Tim
PS, you may be able to tighten up the valves, but once again, if they do not leak when in the fully on position, why risk it.
PPS, I note that 303 is a man of the Black Economy with no tax, NI stamps to pay, he does not have my overheads to sort out, also he wont have two million quids worth of public liability insurance should things go toes up.
I am sure he/she is quite caperble of doing a competant job but please dont say we are just the same but that I am more expensive, its just that I dont have a seperate day job to subserdise my plumbing and heating work. icon_wink.gif
Back to top
 Alert Moderators
emphasis303
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 01, 2008 7:07 pm    Post Subject:
I totally agree with u baker, As im just a diyer i dont have expenses and insurance and having to have a van and professional equipment, my fees would be based on me driving or catching the tube carrying only a couple of wrences screwdriver and maybe a pair of pliers (incase things get tricky as baker said they sometimes do)
I totally feel plumbers and professionals justify their wages, sometimes jobs are a lot more hassle then what they usually seem to be. Also imagine the plumbers coming from far, think about petrol time spent at the shop etc.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Radiator leaks 6 2840 Sat Nov 27, 2004 3:03 pm
Hairline leaks in inaccessible lead pipes 3 180 Mon Jul 14, 2008 9:03 pm
When central heating is on the overflow pipe leaks outside? 6 520 Wed Apr 16, 2008 9:10 am
Testing a solder joint for leaks .... 3 260 Fri Aug 08, 2008 9:10 pm
Leaks from diaphragm on Brittoni 11 T. Big shame 2 100 Mon Oct 13, 2008 8:51 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
