DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
No Manhole/blocked drain
This topic originated from the How to page called Clearing blocked drains
Click here to return to the page called Clearing blocked drains.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Emu2
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 03, 2007 3:13 pm    Post Subject:
Reply with quote Thanks
I have a kitchen drain pipe that feeds into the rain gully down pipe. This goes straight underground, No grid or access point. the water is back flowing out of the kitchen pipe collar.(smelly!) The house is pre war and I have looked high and low for a manhole. The drain runs directly under neighbours drive.
I can only think of cutting a section out of the down pipe and rod? I have tried chemicals. Any other suggestions or do I call the plumber!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
John M
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 03, 2007 3:32 pm    Post Subject:
Could get busy with the diggin' ........ I guess ya need to remove a bit & ideally not brake it in the process...... Angle Grinder to cut the heads off the support bracket boltz ?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Wed Oct 03, 2007 3:46 pm    Post Subject:
surely you could disconnect the kitchen pipe and snake through there?
if it is a rainwater drain someone has put a sink on icon_mad.gif the soakaway might be blocked by tealeaves and bacon fat
Back to top
 Alert Moderators
Emu2
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 03, 2007 6:34 pm    Post Subject:
The kitchen is a built on extension. So the kitchen pipe runs about 25ft along the house to this front rainwater drain. The pipe will not fit a rod down it and too long a run to the blockage.
Pipe is concreted in at base (some design !) so I can only think cut a section out of the main down pipe and rod this and try to remove blockage. Hopefully replace with a new piece.
Back to top
 Alert Moderators
MANDATE
from United Kingdom
Thanked: 10 times
PostPosted: Wed Oct 03, 2007 7:00 pm    Post Subject:
Have you any access to the pipe? from outside. I had a similar problem some time ago.
It was suggested I use my jet washer with purpose made extension pipe which cost around £70. Kept feeding the pipe in, plenty of backwash but suddenly all was clear.
Does that help?
Back to top
 Alert Moderators
John M
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 03, 2007 8:13 pm    Post Subject:
Not got one of those ......... Gotta Jet Ski ....... Any good ?
Back to top
 Alert Moderators
Emu2
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 04, 2007 9:42 am    Post Subject:
I do have a jet washer (Karcher.) Any suggestions on where to get the extension pipe?
Back to top
 Alert Moderators
MANDATE
from United Kingdom
Thanked: 10 times
PostPosted: Thu Oct 04, 2007 6:40 pm    Post Subject:
Got my extension pipe from B & Q and it was for the karcher.
Back to top
 Alert Moderators
Emu2
from United Kingdom
Thanked: 0 times
PostPosted: Fri Oct 05, 2007 9:04 am    Post Subject:
Ok I'm off to B&Q...Many thanks for your all the help.
Back to top
 Alert Moderators
bobs156
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 15, 2008 7:37 pm    Post Subject:
no manhole/blocked drain
there are several answers to this depending on how you want to go about it.
you could
1) dig down on the underground drainage system and clear it from their (but you might not find the pipe because they dont always flow in straight lines)
2) cut the downpipe before it goes into the ground and see whether it is blocked if it just bacon fat/tealeaves then put your hosepipe into it and let it wash through.
and a plumber wont fix this problem they only do clean water
if it doesnt work then you need to call a reputable drainage company
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 148 times
PostPosted: Wed Oct 15, 2008 7:40 pm    Post Subject:
Re: no manhole/blocked drain
speak for yourself
Back to top
 Alert Moderators
MANDATE
from United Kingdom
Thanked: 10 times
PostPosted: Wed Oct 15, 2008 8:02 pm    Post Subject:
I should imagine it's been fixed by now, it's a year since the problem occured.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Backing up sink - air-lock? blocked manhole? Help!! 13 5060 Mon May 28, 2007 4:07 pm
Manhole blocked 18 520 Tue Mar 31, 2009 7:21 am
Manhole cover 3 740 Thu May 15, 2008 11:42 am
Manhole In my kitchen???!!!! Help 8 400 Mon Apr 28, 2008 9:48 pm
manhole cover 6 360 Fri Apr 03, 2009 5:20 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
