DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Laying 20mm solid wood flooring onto chipboard
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
Author Message
hambone
from United Kingdom
PostPosted: Mon Oct 15, 2007 9:37 pm Reply with quote
Hi
I am thinking on laying solid wood floor onto the floor of my new extension which the builder appears to have constructed out of wide TinG chipboard boards.
I wondered what is the best way to fix the solid wood planks to this sub-floor, I wasn't sure if secret nailing would be possible. I was thinking of gluing if necessary but thought this might be tricky if using an underlay.
Any thought gratefully received.
Cheers
Back to top
 Alert Moderators
mattysupra
from United Kingdom
Thanked: 50 times
PostPosted: Mon Oct 15, 2007 10:22 pm Reply with quote
Right. As its your first post ( welcome ) im not going to put to much detail on here yet. So, Dial 'wood you like' into google. Have a look through there website and READ the info they offer. Any other info you want or dont understand then give me or woody a shout on this forum. Enjoy reading
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 212 times
PostPosted: Tue Oct 16, 2007 9:45 am Reply with quote
Let's make it simple: see our article
(Thanks Matty icon_wink.gif)
Back to top
 Alert Moderators
hambone
from United Kingdom
PostPosted: Tue Oct 16, 2007 12:39 pm Reply with quote
Cheers guys, I'll have a look at this & see if I'm sorted, after I posted the query I realised there were some similar threads.
Cheers
Back to top
 Alert Moderators
hambone
from United Kingdom
PostPosted: Tue Oct 16, 2007 1:05 pm Reply with quote
Guys
Thanks for the really useful info.
I will be laying the planks onto 2 types of subfloor, the chipboard in the extension & existing floor boards. I guess then that I get hardboard sheets & then cover the sheets with a foam or rubber underlay to give me one type of subfloor
When it comes to fixing the planks what should I do then ?, the planks are 120mm wide & so I was worried that this was right on the threshold of floating the floor. Might I be better nailing where I can onto the existing floorboards & gluing down the rest to the subfloor ?, but then I was wondering how do you glue a plank to the foam or rubber underlay ?
Cheers in advance
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 212 times
PostPosted: Tue Oct 16, 2007 1:16 pm Reply with quote
Hi Hambone
You have 'one type' of underfloor already: sheet - wood material. You only need to ply one of them is there is a significant difference in height or if the existing floorboards are not level (or if the direction of the new boards go the same way as your existing floorboards).
Solid 120mm we would install floating on foam underlayment in the width of the area is less than 5 meter.
(And you never glue - fully bond - wood to normal foam underlayment - only when you buy the self-adhesive underlayment stuff (good product - Elastilon - but expensive)
Back to top
 Alert Moderators
hambone
from United Kingdom
PostPosted: Tue Oct 16, 2007 2:14 pm Reply with quote
Hi
Thanks for this.
I got an extension put on the back of my house, & so my new kitchen & family room has 50% original floorboards & 50% this chipboard floor. The floor is level throughout but the chipboard does run in the same direction as the original floor, sorry if I'm blathering !.
We want to run the wood floor from the front door, right down the hall & into the new kitchen & family room, would you nail into the original floor where it exists & then float it on top of the chipboard or is that a receipe for disaster ?.
In no area would the width be >er than 3/4 Metre, just as a query, what actaully stops the floor going sideways, is it the weight ?.
Cheers so far, this is really useful
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 212 times
PostPosted: Tue Oct 16, 2007 2:19 pm Reply with quote
Hi Hambone
If your existing floorboards don't run in the same direction as you want your new floorboards going and the existing boards are level enough you can safely install floating on 3 - 4mm foam underlayment.
Ignore the direction of the chipboard icon_wink.gif has no effect on draft or movement of the new boards.
The weight of the boards and furniture on top of it will keep it in place, it's not going to go on a 'walkabout'
We do recommend to install room by room and using thresholds between doorways. (See also our comment on this post)
Back to top
 Alert Moderators
hambone
from United Kingdom
PostPosted: Tue Oct 16, 2007 2:29 pm Reply with quote
thanks mate
you bowled my a googly when you mentioned the direction of the orig floorboards & chipboard.
my orig floor & chipboards run the width of the house & as you've guessed I'm running the planks down the length of the house.
I don't think I'm going to pull the skirting off, do you think thats a mistake , I'll get looking for the foam underlay & adhesive.
Cheers
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 212 times
PostPosted: Tue Oct 16, 2007 2:33 pm Reply with quote
No, think it's a good idea (cause you never know how they are attached and removing them could damage wall, plasterwork etc.)
Leave an expansion gap all around and cover this gap with flat beading (our preferred method for this: handy, easy plus a neat finish - like a 'picture frame')
Back to top
 Alert Moderators
hambone
from United Kingdom
PostPosted: Tue Oct 16, 2007 2:39 pm Reply with quote
thanks mate, only got to do it now, the boss wants it done before Halloween icon_biggrin.gif
Cheers
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 212 times
PostPosted: Tue Oct 16, 2007 2:42 pm Reply with quote
(BTW, I'm a 'boss' too, mate - if you catch my drift icon_wink.gif)
Back to top
 Alert Moderators
hambone
from United Kingdom
PostPosted: Tue Oct 16, 2007 2:51 pm Reply with quote
not a lads only comment, do acknowledge this reality in public also, we'd have never got the extension done if left to me.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
20mm T&G pine board on battens! 5 140 Sun May 27, 2012 6:40 pm
Making 20mm holes in Laminate boards. 20 1180 Sat Jul 02, 2011 8:56 am
Were to buy 20mm polystyrene boards 3 860 Wed May 03, 2006 5:52 pm
Chisel 20mm out of ceiling joist 8 160 Tue Dec 04, 2012 2:09 pm
Leveling an exsisting concrete and slab floor 20mm 13 180 Tue Jun 04, 2013 2:47 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
