DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Adding an extra plug socket
Author Message
garrymum
from United Kingdom
Thanked: 5 times
PostPosted: Mon Nov 12, 2007 12:38 pm Reply with quote
Looking to add another plug socket in my garage.
Currently have 1 plug socket and lights in the garage, fed from a small consumer unit located in the garage (socket and lights on different circuits).
Am I ok to take a spur from the existing socket using 2.5mm twin and earth cable?
TIA
Back to top
 Alert Moderators
RobFurn
from United Kingdom
Thanked: 1 time
PostPosted: Mon Nov 12, 2007 1:48 pm Reply with quote
Thats fine so long as the sockets are RCD protected and the breaker is not any higher than 20A
Back to top
 Alert Moderators
garrymum
from United Kingdom
Thanked: 5 times
PostPosted: Mon Nov 12, 2007 2:17 pm Reply with quote
Hi
The garage is fed from the main consumer unit in the house, with it's own MCB.
Back to top
 Alert Moderators
RobFurn
from United Kingdom
Thanked: 1 time
PostPosted: Mon Nov 12, 2007 4:36 pm Reply with quote
Any chance of a pic of the CU in your garage or a better description of the CU i.e. Old rewireable fuses/MCBs etc
Back to top
 Alert Moderators
garrymum
from United Kingdom
Thanked: 5 times
PostPosted: Mon Nov 12, 2007 4:41 pm Reply with quote
Will upload a pic when I get home from work.
Back to top
 Alert Moderators
garrymum
from United Kingdom
Thanked: 5 times
PostPosted: Mon Nov 12, 2007 7:24 pm Reply with quote
Pic below
Back to top
 Alert Moderators
RobFurn
from United Kingdom
Thanked: 1 time
PostPosted: Mon Nov 12, 2007 9:36 pm Reply with quote
No RCD there Im afraid. Is the MCB from your main CU which is supplying your garage CU on the RCD side of the board?
Back to top
 Alert Moderators
garrymum
from United Kingdom
Thanked: 5 times
PostPosted: Mon Nov 12, 2007 11:23 pm Reply with quote
Does that mean, if I test the RCD from the main CU, does that disable the garage CU????
Back to top
 Alert Moderators
RobFurn
from United Kingdom
Thanked: 1 time
PostPosted: Tue Nov 13, 2007 10:30 am Reply with quote
Yes!
Put your lights on in the garage and test the RCD from your main CU. If the lights go out in your garage then you know the the MCB protecting the sub main cable to the MEM CU in the garage is RCD protected. If the lights stay on you will have to change the MCB to an RCBO or change the garage sockets to these
http://www.tlc-direct.co.uk/Products/CM4901.html
Back to top
 Alert Moderators
garrymum
from United Kingdom
Thanked: 5 times
PostPosted: Fri Dec 07, 2007 12:22 pm Reply with quote
RobFurn wrote:
Yes!
Finally got round to checking this. Right, the electrics in the garage are connected to the RCD side of the main consumer unit in the house. All lighting and the one socket is tripped once I test the RCD in main CU.
So, I can take a spur from the one socket and create another?
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Adding an extra socket on same wall 6 860 Sun Jul 18, 2004 1:48 pm
Adding an extra socket to a remote 4 220 Fri Jan 09, 2009 5:49 pm
Adding an extra socket 2 100 Wed Oct 26, 2011 4:25 pm
Adding an extra socket... 6 3160 Fri Oct 05, 2007 9:15 pm
Loft Wiring (Getting an extra plug socket) HELP! 9 180 Thu Jun 30, 2011 8:44 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
