DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
frozen isolator switch
This topic originated from the How to page called Choosing a shower
Click here to return to the page called Choosing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
pygar
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 12, 2007 2:46 pm    Post Subject:
Reply with quote Thanks
i had a power cut while the power shower was being used, and now the shower wont work and the isolator switch is stuck in the 'on' position (but the led is not illuminated). it seems like a fuse may have tripped but i am having trouble tracking down the problem as it was installed by the previous owner. what are the likely causes of a frozen isolator switch? icon_confused.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Mon Nov 12, 2007 3:38 pm    Post Subject:
please describe this isolator switch
Back to top
 Alert Moderators
pygar
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 12, 2007 8:08 pm    Post Subject:
its looks much like a large light switch, the switch itself is red and there is a small red LED above the switch to denote when its on or off.
Back to top
 Alert Moderators
hi-spec plumbing heating
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 12, 2007 8:13 pm    Post Subject:
that sounds like a 45 amp switch.
can't see why your running a power shower off that anyway
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Mon Nov 12, 2007 8:18 pm    Post Subject:
if it won't move it is probably broken. Start by fitting a new one. If by power shower, you mean a pump that squirts water from the hot water tank, and if it is supplied from a socket circuit, you need an FCU with a 5A fuse fitted.
Back to top
 Alert Moderators
lcgs
from United Kingdom
Thanked: 33 times
PostPosted: Mon Nov 12, 2007 8:21 pm    Post Subject:
Back to top
 Alert Moderators
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 12, 2007 8:28 pm    Post Subject:
even a power shower on the wall don't have a 45 amp switch
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Mon Nov 12, 2007 8:38 pm    Post Subject:
I can't see what sort of switch it is from here.
But who knows what might have been fitted? It might even have been put on an electric shower circuit.
Back to top
 Alert Moderators
lcgs
from United Kingdom
Thanked: 33 times
PostPosted: Mon Nov 12, 2007 8:50 pm    Post Subject:
If he was refering to a large kw rated electric shower, you dont have to have a pull switch isolator if it is switched out side of the zones as per the special locations. A wall mounted double pole isolator of suitable rating will be fine, many electric showers have isolators in airing cupboards and on landings .
Back to top
 Alert Moderators
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 12, 2007 8:52 pm    Post Subject:
then he should put electric shower not power shower
Back to top
 Alert Moderators
lcgs
from United Kingdom
Thanked: 33 times
PostPosted: Mon Nov 12, 2007 9:00 pm    Post Subject:
Good point, well presented which is why i edited my first post.
Back to top
 Alert Moderators
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 12, 2007 9:03 pm    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Frozen condensing pipe 7 300 Tue Jan 13, 2009 8:00 pm
Frozen Internal Stop Cock and Buried external Stop Cock 13 400 Sat Oct 31, 2009 12:59 pm
frozen service valves 3 440 Wed Apr 21, 2004 3:42 am
Outlet Pipe from Worcester Greenstar Ri Boiler Frozen 5 380 Sat Jan 10, 2009 5:34 pm
Drayton Tempus 1 timer frozen 2 80 Sun Nov 08, 2009 9:25 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
