DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Returning Radiators to walls
This topic originated from the How to page called Replacing a radiator
Click here to return to the page called Replacing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Stardust Waymeet
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 12, 2007 6:12 pm    Post Subject:
Reply with quote Thanks
Just had my house fully replastered and the plasterer had a plumber friend come in and remove all the radiators from the walls.
I am now looking to put them back on the wall as the plaster is dry and the world is getting chilly.
I have a combi boiler central heating system. Given that I am simply rehanging the old radiators back onto the wall is it simply a case of putting them on the brackets and rescrewing the pipes back in at either end.
I assume once I've done this that i would fill the system using the little inlet tap next to the boiler?
Then just cycle through the radiators bleeding them one by one and topping pressure up until the system is full?
That all sounds far too easy so is there a catch or is there some problems i need to look out for?
The radiators have been sat in the garage for about two months.
Do i need to fill the system with any kind of cleaning fluid in case there's a family of bugs taken up residence in one of the rads ready to block my system with gunk?
Sorry if i'm asking stupid basic questions icon_redface.gif but I really haven't got a clue about plumbing and I'm somewhat suspicious that I'm missing something obvious.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Breesey
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 12, 2007 6:23 pm    Post Subject:
If all that was done was to remove the rads then, yes, all you need do is refit them. Flush each rad thru with a hose to clean out before hanging. Put an inhibitor in before filling system. Bleed system fully and ensure system at correct pressure before firing up boiler.
Back to top
 Alert Moderators
no66
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 12, 2007 6:24 pm    Post Subject:
What is the correct pressure ?
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 59 times
PostPosted: Mon Nov 12, 2007 6:25 pm    Post Subject:
What you have put is spot on . Before refitting them hose them through in the garden and on filling stick some sentinelx100 inhibitor in.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Mon Nov 12, 2007 7:04 pm    Post Subject:
Just over 1 Bar cold after bleeding and venting system finally.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
mature student (37) returning to proffession 17 900 Mon Jul 17, 2006 4:40 am
Please Help, boiler problem after returning from hols... 6 460 Mon Sep 18, 2006 6:13 pm
noisy heating and dirty marks on walls created by radiator 12 1280 Tue Feb 07, 2006 10:51 pm
ABS waste branch in walls? 38 1160 Wed Sep 06, 2006 4:22 pm
rad pipes in walls 3 260 Mon Oct 08, 2007 8:16 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
