DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
dhw
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
posidriver
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 16, 2007 9:50 am    Post Subject:
dhw
Reply with quote Thanks
i have recently fitted a new bathroom with a nice big corner bath, however i am not able to fill it as the combi boiler cuts out every 10 seconds and sends through a spell of cold before firing up again. does anybody have any thoughts on this problem? my c/b is a alpha 280 and i believe it could be the flow valve or dhw flow valve micro switch. any help would be appreciated. thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
corgigazza
from United Kingdom
Thanked: 5 times
PostPosted: Fri Nov 16, 2007 6:18 pm    Post Subject:
sounds like blocked domestic heat exchanger on the system water side, replace heat exchanger, then fit magnaclean on return fron rads.
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 189 times
PostPosted: Fri Nov 16, 2007 7:22 pm    Post Subject:
Sounds like the plate exchanger is blocked. Either have the system flushed and exchanger cleaned, or powerflush on its own may do the job.
__________________
Don't feed the troll.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
