- Joined
- 22 Oct 2007
- Messages
- 130
- Reaction score
- 0
- Country
A few days ago I replaced the ceiling roses and light switches in one bedroom and the landing. Everything seemed fine, the following day I replaced the remaining rose and switch in the second bedroom. Appeared fine until we went to bed, when we discovered that when we turned the landing light off from either switch it flickered. I assume an incandescent bulb would just dim...anyway I flicked the breaker off for upstairs lights and went to sleep.
Landing light is energy saving bulb, 2 way switching. Wiring is feed from bed1 rose to landing rose then on to bed2 rose. From landing rose we have a 3w+E to switch1, and then from switch1 another 3w+E to switch2.
Problem has disappeared today but obviously somethings not right so began to investigate. Suspected the rose in bed2 but checked everything and all seems correct. Then when I removed the first landing switch I could hear the common moving in its terminal, found it was pretty loose so tightened it up. Obviously as I couldn't replicate the fault I can't be sure I've found the cause, though I'm 99% sure that was it. So just to set my mind at rest, would the loose common cause the light to flicker? Anything else I should check?
Hmmmm...bit long winded but better to get all the info in rather than being asked later
