GaryLovejoy
Joined: 23 Nov 2007 Posts: 2 Location: London, United Kingdom Thanked: 0 times
Posted: Fri Nov 23, 2007 4:02 pm Post Subject: Cold Radiators |
I have just moved into a house that has been extensively refurbished.
I have two radiators that are cold when the rest of the system is warm. All rads are running off TRVs.
One of the cold rads has a warm tail pipe while the other one is completely cold. The are on the first and ground floor.
The plumber who installed the system has told me that this can happen in a new system and has suggested that I turn all the other radiators off and leave these two running for 15mins to flush though and then they should work.
I am not convinced that this is the answer. |
ChrisR
Joined: 24 Jul 2003 Posts: 18663 Location: London, United Kingdom Thanked: 62 times
Posted: Fri Nov 23, 2007 4:32 pm Post Subject: |
Won't cost you much to try though, will it??
Do a search on airlock.
Can also be stuck trv's - see faq. |
GaryLovejoy
Posted: Fri Nov 23, 2007 4:42 pm Post Subject: |
Thanks. I was going to try tonight, but was interested if anyone else had a quick answer |
Prof.plumb
Joined: 09 Feb 2006 Posts: 188 Location: Leicester, United Kingdom Thanked: 2 times
Posted: Fri Nov 23, 2007 5:10 pm Post Subject: |
If the rads are full of air turning all others off will force the water to circulate through thoses rads, thus clearing any air. However, if the trv is stuck in a closed position you simply need to free off the pin in the valve. Take the head of the valve and give it a few taps then it should come on. |
bengasman
Joined: 28 Jan 2005 Posts: 10120 Location: London, United Kingdom Thanked: 188 times
Posted: Sat Nov 24, 2007 12:48 am Post Subject: |
Do a search on this topic, you are bound to find the answer readily available __________________ Don't feed the troll. |
